Nope, won't say it...you know my thoughts on them.The only one I have used is the Ridgid branded one, which is actually made by Viega, the cordless one is much lighter than the corded one. We don't own one, we rent them when we have a job that we want to use it for, which may became a much smaller number since the fittings failed on the last job we did with Pro Press fittings.
We used pro press on some water feeds for gigantic printing presses, and the constant vibration works the crimps loose on roughly a monthly basis, re-crimping the fittings is a temp fix, but we will be re-piping the presses in December when they shut the presses down for maintenance.Just curious.. The o-rings failed? The reason why I ask is because my boss has talked about doing some small repipes with the Pro-Press. I have had a little dealings with it when I first started service but its been awhile....
I don't know, I haven't seen one installed long enough to have a good opinion. We have never installed one where we do not have access to it either, mostly we have used them coming off of risers that don't get a good shutdown, and we go back to soldered fittings right after the isolation valve.In a stable enviroment they work pretty well then I take it? Im kind of leary of them myself. I guess I just came up sweating and I dont want to do anything else unless there is no other way...
An exaggerated version of standard shock & seizmic motion on any water piping system, very exaggerated.We used pro press on some water feeds for gigantic printing presses, and the constant vibration works the crimps loose on roughly a monthly basis, re-crimping the fittings is a temp fix, but we will be re-piping the presses in December when they shut the presses down for maintenance.
I would be far more concerned with PEX in this reference, a simple crimped joint on a materiel that is known to expand and contract at a large margin at low temperature variations, to me the product is a failure waiting to happen.An exaggerated version of standard shock & seizmic motion on any water piping system, very exaggerated.
I betcha thermal expansion plays an eventual role as well.
