"Collective minds produce creative and sometimes dangerous thinking" (tl 2009)
Hey Guys
I have to know that some of you out there have been in the business for a good many years. I can tell by some of the banter on this site that many of you have a quick whit and sharp minds. Having said that…..the knowledge you have acquired over the years should be shared with others.
If you could invent something to help guys in this business, what would it be? It can be something as simple as your favourite “trick of the trade” that you could patent.
I’ll start:
Mine is a “Tool-a-tron Spectometer”. It’s an electrometric coil 10 inches in diameter that plugs into any 220vt circuit. Once plugged in, you pass each and every tool you own through the coil. The tool-a-tron takes all the negative ions and makes them positive in your tools. They remain this way for approximately one month at which time they will need to be re-charged. With the tool-a-tron you get a lapel sensor you can pin to any part of your clothing. As long as the tool and sensor are within 100 feet of one another, nothing happens. When your at a job site, and start to leave the premises, if you’ve forgotten your favourite pipe wrench or screwdriver, the sensor goes into a rendition of “mares eat oats”. You quickly realize you have forgotten something and return to pick it up. Simple but effective. No more screaming from the little lady cause your buying more tools. You’ll never buy again. And all for the paltry amount of only $19.95. Is this freaking brilliant or what???
tl
Hey Guys
I’ll start:
tl
