1 - 5 of 5 Posts
Hello,
Been looking in to the theory about heat exchangers but don´t quite understand if the plates themself contains and transfer the liquid that is running or if the plates simply transfer the heat via the metal?
Hope you understand, English is not my first language and yes, i´m an apprentice.
Thanks.
An intro is requested from all new members. In case you missed it, here is the link. https://www.plumbingzone.com/f3/.
yes, it's the plates that transfer heat via metal, liquid is not transferred but kept separate. liquids are kept separate because you are likely using hot non-potable water from a boiler to exchange heat with potable domestic water.
heat exchangers can also be used for low temp heating applications. for example you may have a baseboard heating zone, and a radiant heating zone in the same house. the high temp will run the baseboard, and a heat exchanger will be installed to supply heat for the radiant (low temp). this is if you only have one output temperature from the boiler.
Engineering
There are mainly two types of heat exchanger
1.shell and tube type
2.Plate type heat exchanger
A plate heat exchanger is a type of heat exchanger that uses metal plates to transfer heat between two fluids. This has a major advantage over a conventional heat exchanger in that the fluids are exposed to a much larger surface area because the fluids are spread out over the plates.
Working
With a plate heat exchanger, heat cuts through the surface and separates the hot medium from the cold. Thus, heating and cooling fluids and gases use minimal energy levels. The theory of heat transfer between mediums and fluids happens when: Heat is always transferred from a hot medium to a cold medium.
Working
1 - 5 of 5 Posts
