Pipe Freezing Methods
61K views 62 replies 34 participants last post by  Greenguy
There is no such thing as liquid CO2. CO2 sublimates directly from a gas to a solid. There is no liquid phase for that compound.
We do that all the time to replace curbstops on water services. We use the General "Cold Shot" it uses liquid CO2 to create dry ice around the pipe. Works great but the water flow has to be stopped.:yes:
There IS no such thing as liquid CO2 at atmospseric pressure. My point in saying that was that you cannot just pour liquid CO2 over the pipe or into a trough around the pipe like you could with liquid nitrogen. That's it.
You should do your homework before claiming your expertise about CO2.:rolleyes: Look up dip tube CO2 tanks. The following is taken directly from the General website.
"The Cold-Shot is easy to use. Just place the
freeze head around the pipe, attach the hose, and open the cylinder
valve. Liquid carbon dioxide will flow into the freeze head and form
dry ice with a temperature of minus 110F° (-79C°). That’s cold
enough to form an ice pack that can withstand 7,000 psi,
yet won’t damage pipes."
http://www.drainbrain.com/specialties/coldshot.pdf
