1 - 11 of 11 Posts
My 69 Sovereign has a couple of copper water pipes that appear to be split/cracked I am assuming from not draining properly in the winter
It seems like favorite product used to repair is the pex product.
Does anyone know the recommended size used to connect to the original plumbing?
Do they make an easy connector to connect the copper pipe to the pex tubing.
Drain Cleaning Specialist
:whistling2:
AKA house plumber
The schwinn coupling is as funny as this helper at work that tried to repair a broken 1 inch pvc water service with the blue sleeve used to sleeve copper though the slab and 2 hose clamps.
Dont worry about using pex, a piece of radiator hose will do the trick, make sure you post pics and show us your beautiful work.
1 - 11 of 11 Posts
