1 - 15 of 15 Posts
Discussion Starter #5
Hats off to the people who came up with the idea in the first place. If I'm not mistaken, it was Fein Tools.
thats the brans I have for the tool and some blades, but I found the generic blades work almost as good at a fraction of the price, so now I just buy generic blades..
As long as quality is not sacrificed, I do that anywhere I can, even with household products like razor blades.
Discussion Starter #7
Ive noticed the generic blades hold up quite well, and at 1/10th the price...of name brand I say I get 80 % use out of generic compared to name brand, and if I have to destroy a blade cutting something nasty, I dont care as it was only a few bucks..so im my opinion..the generics are well worth the money..
heres the generic
heres the fein blades, BIG difference in price..not much on out performing generics..
Discussion Starter #8
heres 50 wood blades for 78 cents each..
heres 10 fein wood blades for almost 10 bucks each..
heres the generic
I charge any and all blades to the job,sawzall,multi-tool blades whatever,if I ruined a blade on your plumbing or whatever it's going on the invoice along with Teflon tape,pipe dope,papertowels etc
I do the same, the other week when I had to cut tile to access the tub escutcheon the guy exclaimed the materials were expensive, go ahead file a complaint to argue the bill if he wants but the diamond blade on the grinder and a new 15$ sawzall blade ain't free.
Sometimes when I see someone might cause problems I write everything down in details instead of just writing (solder) I write : sand paper, flux, solder, propane, welding blanket, teflon, pipe dope etc.
Discussion Starter #11
I flat rate price, so its all built into the price...
Pornstar, Service Plumber
We charge a 5$ consumables fee on almost all bills. We try to charge out as much as we can but that 5$ fee makes up for a lot.
I have one of these tools, I got it when I was replacing some flooring at home, it worked great.
I don’t really use it for work other then if I need to cut out the back of an existing cabinet to access the pipes.
I only use mine a couple times a year, but when I do, it's a frickin life saver.
Reactions: Tango
100% agreed!
It was great for the flooring, cuz the new floor was about 1/4” higher then the old, it made cutting the door frames/trim super quick and easy.
1 - 15 of 15 Posts
