1 - 14 of 14 Posts
LeMarr Plumbing, Inc.
What is your charge to jet.
I am flat rate but at times flat rate on a drain (cable) clean can hurt but since I am looking at a jetter, I may do $? for the 1st hour (1 hour min).
Some I have talked to does 250 - 350 per hour with 1 or 2 hour minimum.
Just checking what you, who have jetters, do as far as charges.
In Christ,
Song Dog
Illinois Licensed Plumber
For out trailer jet we tell them it would cost them $650 for the first 2 hours if it takes longer than that then we charge 80 per half hour. The Combo unit Jet/Vac we charge $350 per hour minimum 4 hours portal to portal, and 50 cents a gallon for disposal.
Drain Cleaning Specialist
$350 2 hr min. seems to be the rate in Boston area. Then it's like $150 per hr after. Thats what they were getting when I left.
Flat rate of $425 for residential (single line). If you haven't gotten it in 2 hours with one of the smaller jetters (J-2900 for me) you're not going to and it becomes a repipe. I pretty much always upsell ks and wm drain lines to the jet job. I rarely jet a main because the former two will be grease and the latter will be roots or something else the cable will be better for. However, if I can find a descaler and a root chain that I have confidence in for my J-2900 then I may start selling main line "cleanings" as well. I do very little commercial and have never yet used my jetter on commercial.
I'm in the same boat as you not much commercial. I have a small Water cannon electric jetter 2.2 GPM @ 1500 PSI good for Kitchen sink drains and floor drains with 1/8 x 50 feet jetter hose. Have a reel of 3/8 x 150 feet has a hard time pushing past 50 feet.
I am looking at a J-2900 how is it working for you? I would be happy if it can push 125 feet of 3/8 Thrilled if it could pull 200 feet of 3/8. They have a what is it J-3000 looks heavy and takes up a lot of space. J-2900 looks a lot more easy to work with.
mine doesn't start up for less than $450. usually much higher than that.........much much higher. I charge a flat rate for the job and give a warranty. Doing one right now on a kitchen line(cast iron) for $637.
You won't have enough arse to spin a chain nozzle with that rig. Better stick to cables for the roots until you can get a bigger pump.:yes:
A pic of the one I did this morning. Snapped a cell phone shot while I checked the nozzle on startup. I had it tied to the guy’s fence to check the jet ports.
used my j2900 today at a dog pound.works great on dog poop , food and mud from the pens and kennel. 3hrs around $600--side note you will want to invest in some type of itch cream for all the flea bites!
Discussion Starter #11
:laughing::laughing: Our office is next door to Allied Pest Control:thumbsup:
In Christ,
Song Dog
My J-2900 will pull every inch of 200' but I never even bother using it for anything less than 3" which means I really hardly ever use the 3/8" line except for when I need to remotely locate the 1/4" hose reel which is not often. The thing I use the 1/4" hose for most is ks lines. However, when I occasionally run into a sludge plug that the cable simply passes through without breaking it loose, there is nothing like that 3/8" line blasting away. It will knock it out and I mean right now! Don't blink 'cause you'll miss it!
1 - 14 of 14 Posts
