1 - 13 of 13 Posts
today i spent the day with my k 40 and a box of cutters/augers trying to clear a 1 1/2" line that was filled with the clay slury used for leveling concreat floors they must have drilled into it and pumped in the sand/clay mix
towards the end of day i had an idea to take 1 of the blades from my power vee's small "C" cutter and used it to dig in and it worked a bit better than the ridgid cutters
in the morning i have to go back and spend my day again clearing this drain anyone goot any great ideas to clear it
Registered User
Hello! Introduction Requested
An intro is requested from all new members. In case you missed it, here is the link. http://www.plumbingzone.com/f3/.
Discussion Starter #6
@ ianclapham
we tried but i need to get a hole through for the water to drain and let some erosion happen. the blockage is between 6 and 8 feet down the line.
also it is under a brand new tile floor
Sounds like some idiot is going pay through the nose to repair/replace that section of pipe.....:whistling2: Back charge the tile geniuses. Have your customer pay you and let them go after tile setters. You have a blank check.
I Married Up
I doubt a K-40 will do you any good. Maybe a K-50 but that is a big IF.
Jackhammer time. :hammer:
Anything concrete sets slower under water typically but at same time hardens harder because of a slow cure process. Many are under the illusion concrete won't harden under water. I've busted out 2" traps for same reason. ( Gotta love tile guys). Had one bunch busted a bag of mortor near 2" drain and of course alot went down drain. They never said anything buttttttttt. It all came out of course with a sawzall and was "hard as a rock".:laughing: Fortunately it works better if they haven't been washing tools etc off and laying a nice flat bed strung down the drain.
Ridgid actually sells an auger bit that is designed to break through concrete. I think it has diamond dust on it. This'll give you another option. I don't know what cable you have though. Might not fit.
Discussion Starter #12
I did it i aculy got it clear. fortunately it was not a concrete product, i used my k 40 and a blade i made from stainless steel and my jetter through the trap arm and i adapted an old transfer pump to the clean out after the first blockage there was another 4' after it same thing
Nayman's
You're lucky.
I've had concrete companies pay for redoing traps, Floor sawing, and re-tiling for the same kind of negligence.
Walmart does not look kindly on their pipes not working properly.
1 - 13 of 13 Posts
