1 - 20 of 25 Posts
Pornstar, Service Plumber
Get a new gfci if the old one is bad. I too have been electrocuted enough to know they are worth the trouble.
Yes they are, but i have a vac pedal from them
The sled machines I used in California had electric pedals. POS machines. If I didn’t have to rent them from the company I worked for, I would’ve converted them to pneumatic. I’ve been poked by 110-440. That’s nothing compared to D/C. That sh*t hurts like a SOAB!
99% sure you have a gfi problem. My brand new 300’s gfi crapped out within the first few weeks. Thankfully I had a male replacement end on my truck. Embarrassing when your equipment fails on a job, even more embarrassing if you can’t fix it and have to walk.
Discussion Starter · #10 ·
Seriously, I had to walk away from a drain call I know I could have cleared with that machine but there was no way I was going to get the 1065 in that spot and the go62 was down so it was what it was
My foot pedal got a hole in it a couple weeks ago. I jumped out the air switch and used only the toggle switch on the motor for a few calls.
Normally I keel a spare foot pedal as they do get holes sometimes. Never had the actual air switch fail before the motor. We keep a spare motor at the shop, spare everything pretty much.
Years ago, in the dead of winter my first job was a main line in a trailer park. No clean out so I had to pull the toilet. Got all set up, stepped on the pneumatic peddle and nothing. K750. So I stomped on the peddle and it turned on but wouldn’t stop. I think the switch had some moisture in it and had froze. 45 minutes from the shop I figured I’d just use the toggle switch. Bad move. Once the cutter hit the trap the cable locked. If a single phase motor is turning in one direction and you try to reverse it, it will continue in the original direction. Everything probably happened in seconds, but felt like forever. Cable flipped in the drum, then wrapped around my thumb and as it kept failing in the drum it was pulling my wrapped thumb into the autofeed. I finally yanked the cord from the wall to stop it.
I only use machines with an inner drum now. If it’s not working perfectly, I’m not working.
The switch on my General has an off position. I'm not saying it's safe to use a toggle switch in lieu of a foot pedal, just that I've done it.
Discussion Starter · #17 ·
Well i finally got around to swapping out the gfi and the plug yesterday, gfi has power but motor still doesnt I guess ill change the 3 way switch and see what happens, if the motor is shot im not sure if ill replace it or not
Discussion Starter · #19 ·
Did you change the switch??? If electric from factory then you go with air you have to put a air switch in place of the electric one would seem to me
the pneumatic switch is a trick little conversion switch all the pneumatic is handeled in-line, lol i hope you dont think im plugging an air foot pedal onto a random bolt or something hoping it works, also i am plugging the machine in direct from wall to test
Discussion Starter · #20 ·
final update on this because I know when I look something up and find an incomplete thread with a question I had it drives me nuts. I replaced the 3 way switch, tightened up a couple connections between the gfi and motor tested it and it worked!! so if anyone has a similar problem just replace everything and it will be fixed lol.
1 - 20 of 25 Posts
