141 - 160 of 161 Posts
· Registered
RETIRED Pornstar, Service Plumber
What would you do without a camera???
Not work as hard.
In that instance I would have cut the wall open instead of dicking around for 20mins trying to get the snake to go down. There would be a lot more cases where I could simply say must be broken or you have to dig.
· Super Moderator
Discussion Starter · #142 ·
I don't own a camera. A few years back I toyed with the idea of purchasing one, but opted to purchase electronic leak detection equipment and it hasn't disappointed. With slab leaks {for those of us who live where basements are few and far between} it is an easy sell to locate a slab leak. If fact, there is no selling involved, it sells itself. People don't have to be talked into locating and repairing a slab leak.
But I don't think that it is as easy to sell a camera inspection. Once the stoppage is cleared, people are like, "thanks, if it backs up again, we'll call you to inspect it with the camera." In my opinion, a camera is a more difficult add-on to sell. I have had drain line stoppages where I was highly recommending a camera inspection and they didn't want to do it. I would say something like, "We should investigate this sewer line and locate the bad spot so it can be dug up and repaired." And they were not interested. Just my observation. Maybe others are skillful at selling camera inspections, but I wasn't.
So I could never justify spending $10,000 on that tool. I could not see a meaningful ROI {return on investment} whereas getting into elec. leak detection has been a real winner.
A friend of mine bought the mini or micro camera for $5,000 and he was dis-appointed. He wasn't selling sewer repairs and also, the push cable was not that stiff. Even though it had like 100' of push cable, he had trouble sending the head down sewer lines that far, because the push cable would tend to kink on him at around 50' or so and he was un-happy with that camera.
So I wisely stayed away from purchasing a camera.
· Super Moderator
  • vision-hd-camerahead
  • VisionHD
  • VisonHD_with_logo
  • VisionHD_2
  • VisionHD_3
  • VisionHD
VisionHDVisonHD_with_logoVisionHD_2VisionHD_3vision-hd-camerahead
VISIONHD 1080P CAMERA SYSTEM
  • 1-1/2″ – 4″ Lines
  • 1″ 1080P High Definition Self Leveling Color Camera Head with 8X Zoom Feature
  • Spring with Built in 512Hz Transmitter
  • 10.2″ LCD Monitor with DVR, Speaker and Microphone for Voice Recording
  • Keyboard for Text Writing
  • 100′ of 3/8″ Flexible Push Rod to Easily Maneuver Bends in Any Pipe
  • Foot Counter
  • Durable Protective Case with Partitioned Reel Housing for Quick Removal and Cleaning
  • Three Additional Input Connections For Use with the 200′, 400′ and Pan & Tilt Reels
  • Works with AC and DC Power (7hr Battery Life)
  • Includes: 2 Skids with Quick Change Adaptor
  • 64gb SD Card with USB, Micro USB and USB-C Adaptor and Charging Cord
PRICE
$3,995.00
· Super Moderator
Customer asked me if I can clean her dryer vent. No problem, I turned the SuperVee into the dryer vent cleaner 1000. I taped a rag to the cable and shot it through with my shop vac on the other side.
This is brilliant, I hope I can remember that one!
· Registered
I wish moen would come up with a tool to pull a 2 handle cartridge out instead of trying to pull on it and practically pull the sink off the counter.
Use a nipple with a cap, drill a hole in the cap, place it nipple side down over the valve body, drive a lag screw through the hole and into the plastic stem. As you tighten it will pull the stem out.
· Registered
Do you use the nipple. Also what size 1/2 or 3/4?? Would you be able to show a picture of what your doing?
You can use a 1/2" or bigger nipple, roughly a couple inches in length. You don't even really need a threaded cap, it could be a strong washer with the right size hole for the lag screw.
Think of a Moen plastic two handle stem, it has that center hole for the handle screw. You can drive a screw/lag into that hole. Then you can pull up on the head of the screw/lag. Often I will slip a wrench of some kind under the screw head and pry it up. The benefit of using that nipple/cap is as you drive the screw in it bottoms out on the cap and since it can't go down the stem comes up. You won't be prying on the edge of the valve body and risk damaging the bonnet threads.
· Registered
Plumbing
· Registered
@Tommy plumber
Scroll through the pics. You may be interested.
I just use a wheel locknut socket. It was ~12$ at the local autoparts store. I have them in a few sizes on the van because some large PRVs require them for disassembly. Of course Apollo doesn't tell you this in the manual....
Gesture Font Material property Metal Logo
· Registered
Trying to loosen the thin hex bonnet on a Sloan flush valve inside of a wall with a socket will only round off the corners of the hex: Unless you crawl inside the wall and try to steady the socket with one hand while you pull on the handle:
The hex is only 1/4 inch of chrome plated yellow brass and if it has not been moved in a while, the only way is heat and a straight pull thru a 12x12 access panel. Exposed valves are child's play----- go bust your knuckles in a jagged masonry wall and leave some skin on the brick ties and rebar. Bet you will put that socket back in the toolbox.
· Registered
Plumbing
The socket was posted as a tool to remove and install flushvalve nuts for kohler two piece toilets that install inside its tank to Bowl gasket.
We’ve moved on from the sloan valves.
· Registered
I don't use a socket for sloan valves, as Terry explained it's for Kohler T/B seals.
And yes, I have plenty of experience with concealed Sloan valves. I have a Sloan Superwrench but usually just use sharp Channellocks.
Did you know if you grind the end of a socket it will be sharper and bite onto shallow flats?
