Name that faucet 2
702 Views 19 Replies 7 Participants Last post by  Plumbus
2
Any help would be appreciated.
See less See more
Reactions: 2
1 - 20 of 20 Posts
Not only a Rohl, but a discontinued one.
Reactions: 2
Guess its time for a replacement then.
Reactions: 1
I almost never work on lavvy or kitchen faucets, 99 percent I replace with new if they are having issues.
Reactions: 2
same. Unless its a delta or a moen that's fairly new.
Reactions: 1
With faucets like this one, it's usually not a mechanical problem. It's a missing part or worn plating.
Reactions: 2
I can repair or replace, it’s the customers choice. Some faucets are worth repairing, some are not.
Reactions: 1
Terry
We don't do service (unless there's a gun at our head). If you were local, you'd be my go to.
Reactions: 2
Terry
You don’t service them? You hooked me up in 2016 and I still appreciate your help with it. Thank you again.
Reactions: 3
Terry
I can't imagine selling something so expensive to a customer and not servicing it. Reminds me of all the 'Water Conditioning Specialists" who charge someone thousands of dollars and then are never heard from again when the customer needs it fixed a couple years later.
I get it, you're a new construction company. I just couldn't do the same. I assume you will come repair/replace something within a warranty period?
Reactions: 1
Most faucets are just so cheaply made they dont hold up afyer a rebuild
Reactions: 2
That faucet is likely 800$ to 1200$ and is most definitely worth fixing. Most higher end two handle faucets use almost identical ceramic stems and almost always common size orings.
How often do you fix faucets?
Reactions: 1
Almost never, unless they are high end i wont even entertain the idea
  • Haha
Reactions: 2
Do you drive an open body pickup and work on mostly modular homes?
Reactions: 1
No
I have customers that call me and say “ Bring me a faucet that won’t break the bank “
So I take a $200 Delta and it have a lifetime warranty through Delta.
After a few years of it develops a drip, I would be embarrassed to try and sell them a new faucet.
So of course I repair it.
Some faucets are part of a matching collection in the bath. It’s a hard sell to replace 3-4 other faucets because one is dripping and can be repaired.
I give advice. My advice isn’t always “ replace it “. The more faucets you work on the more experience you get and hopefully the better you become. I like to be more than an installer, I’m a mechanic.
You get the idea.
See less See more
Reactions: 1
Let me clarify. Generally, after warranty, we don't service. I try to link up the HOs with a colleague.
Reactions: 4
1 - 20 of 20 Posts
