1 - 20 of 28 Posts
Its bad enough I got to deal with a defective gas valve on Rheem,,,, but
now Bradford white has a defective anode rod in their heaters and it
makes the faucet spit air and all sorts of god awful stuff out of all the
hot water faucets......
So I go out to change the rod in one and it turns out it needs a socket set
and a cheater bar to change the frigging thing out and I got the wrong one..
I lose my cool and just tear the dam thing out and install a Rheem electirc for the
lady in less than an hour.....
I drain the 5 week old bradford white electric in the driveway and the stuff pouring
out of the heater looks like donkey cum.....
they got troubles now too.....when will it all end???
127907
127908
years ago I forgot what brand, but the dip tubes disintegrated into little white pieces and they had a campaign to replace them, they were paying some cheapo price for plumbers to do it, again it was long ago and i dont remember the details...it wasnt worth it because the customer expected you to clean all the airators on the sinks and wherever else the crap collected and caused issues..and I can bet where most of the problem parts came from..CHINA...
Discussion Starter #3
[/QUOTE]
That was Smith back in the 90s...they got the brunt of that problem
and that was a cluster/uck....
Yep the company I worked for was a Bradford White factory rep. There was a bad plastic mix and the dip tubes disintegrated plugging everything including dishwashers, faucets, etc. The manufacture sold dip tubes to several WH manufactures. We were seeing people having to replace washers, dish washers. WH companies were not standing up. I got ahold of my local county newspaper ands since I was a local inspector they ran the story. May have helped some home owners re-coupe the costs since al the WH manufacture would cover was the dip tube replacement.
NJ Master Plumber
View attachment 127907 View attachment 127908
Curious if you were ever able to get the anode rod out, how that looked? I've had pretty great luck with bradford white
Pornstar, Service Plumber
He couldn't get it out, that's why he replaced it.
Ever seen cheap diecast handles/tub spouts/shower trim corrode to nothing? White rust and dark grey? That's what that anode rod looks like.
My guess isn't that it's a bad anode rod, but the wrong anode rod. There are 3 or 4 different alloys and they ship water heaters to different parts of the country with different anode rods for different water qualities. Probably got a load of different region heaters.
Never under-estimate the effect differing water quality will have on two otherwise identical plumbing systems. It's the reason some guys love one brand while other guys hate it, they have different water.
ding ding another winner...
Discussion Starter #8
I did not have the deep socket wrench with me to tackle the anode rod buried 3 inches down in the heater...
sort of glad I just changed it out because I probably would have been flushing that pig out
for 2 hours just trying to get the grey matter out of the unit....
I am still gonna turn in a warranty call for 200 bucks to bradford-
I might attempt to wrestle that rod out of that heater tomorrow morning...
I was in the flow today and was too busy to fool with it or lunch too---
did 3 heaters in all and was home at 4.30....
Looking at the heater size they are so damn slim, that's why you can tackle twisting stairs unlike me. Our heaters are way wider!
Discussion Starter #10
I am not really argueing with you,
I am just wondering why you throw in 60 gallon units???
why is that the common one in canada...??
Discussion Starter #11
In our area if you have a water softener the Rheem units last a lot longer than Bradford Whites....
The Bradfords might last the warranty life or not and go out a few weeks after 6 years....
most Bradfords fry out at about 5 years old around here....
The sodium in the soft water eats the bradfords alive....
No water softener in the home and both will last 10 + years......
I have come across the air in faucet also but why is a anode rod able to cause air to so it out at the faucet???I never did figure that one out yet
as the rod dissolves I believe it creates a gas, and thus gets pushed to the faucet.....like fermenting mash for liquor, you can see the bubbles forming...
You'd have to figure out what chemicals/elements are in the mix and then look at which ones can become gases. A couple off th top of my head would be sulfur, chlorine, oxygen, and nitrogen. I think nitrogen would be the most likely culprit as you haven't mentioned a smell. Nitrates and nitrites are common compounds you might find in water.
Reactions: sparky
Discussion Starter #16
We have either 40 gallons or 60, remember that 60 canadian gallons is 74 US gallons
So a 40 in canada is basically about 55 gallons us and a 60 is 74 gallons us......huh
You must have a lot dirtier butt-holes in canada too need all that much hot water...
Il Lic. Plumber
I installed a Bradford White Natural gas water heater last week. Customer wanted it added to his system as his large family was using up all the hot water in existing heater. Usually connect 2 heaters parallel to each other. Someone had exchanged original nipples on top with brass for Watts recirculation pump system . I went to replace nipples on new heater to match existing one . Pulled hot side and
Anode rod is attached to outlet nipple. Never seen that before. Change of plans . Put nipple with anode back in . Connected heaters in series and all is good . You all know the difference between series and parallel?
Are the anodes the same with Bradford White electric models ?
I have had good luck with Bradford White heaters . Made in the USA . Entire bottom of combustion chamber is screen for air intake, unlike the rest that use a 4 X 10 screen that get blocked easily.
Discussion Starter #18
it depends on where you are in the usa.... just get ready for complaints
about spitting and sputtering air out
of all the faucets,,, then sediment later on...
Did you read my soaps?? Lots of soap needed for dirty A-holes! :ROFLMAO:
I went to check the specs sheet, a 41Imp gallon(what we call a 40 for a 2 person house) says it's 49 US gal. Pretty confusing crap when we are supposed to be metric for the last 40 years but plumbing is still dominated in Imperial numbers.!
Sounds to me like they're just calling 4 litres a "Gallon". Not really confusing when you realize they just swapped 4 litres for the 4 quarts you'd normally find. Basically your "gallon" is just a bit bigger than ours. I guess you could say you have a "metric gallon".
Kind of like what they did with the "Ton". A short ton, or US ton is 4,000lbs while a long ton, or metric ton is 4,400lbs because a long ton/metric ton is 1,000kgs and a kilogram is 2.2lbs.
1 - 20 of 28 Posts
