I hate them. had a problem with the hold down nut on one model. No matter how tight you tighten it if the home owner bumped the faucet it will leak under the counter. Finally had to use some lock tight on it. Next, the same faucet she called back. No water pressure at the sink. Look under the faucet and that damn 6" hose that plugs into the tee and has to turn a quick 90 to the valve had kinked. Went and got a new hose and this time I put a round block of wood in the center of the hose so the damn thing wont kink again. HO purchased it and said they spent way too much money to replace it right now but said the next time they will not buy a Moen.
