Came across job today ,stoppage was in closet bend. It was about a 2' drop from flange to bend seemed a bit excessive.Cant find max distance in code book.
Good question I have a e-mail off to a state inspector, will let you know soon I hope.Bottom of the outlet or water level of the trap.
Let's say for arguments sake you have a WC on top of a 4" stack that drops 10 storys. Let's also say the stack has a vent coming off of it 1' below the WC and continuing full size through the roof.
Does this meet code?![]()
It meets code in my state. The offsets in the stack would be made with 45'sGood question I have a e-mail off to a state inspector, will let you know soon I hope.
This has come up in code related classes once before.
OBC 7.5.6.3 (3) (Discussing vents for siphonic fixtures)Up here we are allowed a max 3' vertical leg or drop then we have to turn it horizontal. Total pipe 5 ft max then vent.
Dont forget I am Oldschool ....it going to take a while before I am up to the new OBC code from the old OBC..... back then we didn't even use metric .... all imperialOBC 7.5.6.3 (3) (Discussing vents for siphonic fixtures)
(a) 1 000mm (3.3ft) in the vertical plane ***
(b) 3m (10ft) on the horizontal plane
There's a little bit of OBC wisdom for you that will surely come in handy one day
***Pop quiz!!
Anyone know WHY the vertical drop is limited to 1M (3.3ft) ???
The code has changed quite a bit. Many of the people I work with refuse to hear ANYTHING about this new code. Which is fine, I suppose. If it has worked for 20 years, I'm sure it should work for another 20.Dont forget I am Oldschool ....it going to take a while before I am up to the new OBC code from the old OBC..... back then we didn't even use metric .... all imperial
3' was the number back then and 5 ft of pipe max to vent ..... now you say I can run 10 ft of pipe then vent . Some of the stuff they have changed are way different like wet venting from the floor above. More than likely it will take a while find it all out as most of the time it is the inspector that tells you what is wrong... The old OBC code will never get called out by the inspector as wrong as it exceeds the new OBC code
Tommy I don't think that section applies to water closets as the vertical drop in question is below the trap weir.![]()
Something like this TommyCan you post a quick sketch? I am having trouble picturing this in my mind. Forgive my dumbness. :laughing:
Vent stack yes.Pic would be to code if it had a vent stack and a yolk vent.
82.33-4 is Indirect and Local waste. I think you meant 82.32 (4)(b)1.c.Sorry there RW but the max drop in Wisconsin is 36" from the waterline of the W.C., not from the floor. Don't know where you got 6 foot or 60 inches whatever it was. I think a freestanding spit sink in a dentists office might be 60" but a W.C. is 36" 82.33-4
