21 - 40 of 59 Posts
· Registered
Why would you need to drain the tank? It has a bladder in it. It won’t get water logged.
You drain it when it goes bad and you need to change it.....
My peeve is when they get installed nipple up. I install my dom. hot exp. tanks nipple down, preferably hanging on rod if they have the nut welded to them.
· Registered
· Registered
Then you have to drag in an air compressor. i'd rather have a drain.
Do you stock an expansion tank in your van? Do you make a run to the supply house? Or do you diagnose the problem and schedule a return visit?
· Premium Member
I can send you a mounting brack for that tank.
Also does no one install a boiler drain with there expansion tanks so you can easily isolate the tank and drain it with out killing the hot water.
How do you tune them when you install them?
I read somewhere valving an exp tank is bad. Last one I saw i used it to change the tank and left it. The employees weren’t going to be touching it.
· Registered
That's why we take the handle off if there's a valve. The only problem with a valve on an expansion tank is someone can turn it off if they don't know better. Tank leaks, someone just shuts the valve and leaves a note that never goes anywhere.
Most of the houses we work on that require an expansion tank are the kinds of houses with a property manager who keeps things straight, so often we will put in a valve to make our lives easier.
· Registered
I take care of the same 30+ buildings plumbing. So I can do both 😂
Well see that's not a normal service plumbing scenario. No need for a drain in my case because first service call is diagnosis, I add air to get them by till we return. Upon return just shut cold to heater, drain some from the bottom of the heater and the air I added last time will empty the tank for me.
· Registered
Even when I was a service plumber I installed a valve and a drain. but there is many ways to skin a cat.
· philosopher and statesmen
I’ve never seen a valve or drain dedicated for an expansion tank. Sounds like a waste of time and fittings, and therefore money. A rag and a bucket are coming in if there’s a drain or not. Why complicate it, to save yourself 45 seconds every 5 years it needs swapped out?
the valve is a good idea but we rarely see them...and I dont care to do that neither
I have gotten some calls where the expansion tank tricked the owner into thinnking that
their main water shut off to the home was broken because the expansion tank kept
pushing water through the lines for about 4 minutes or more....
I suppose the expansion tank could literally flood the shi/ out of a house before it finally
loses pressure
· Premium Member
loses pressure
What the f are you talking about? An expansion tank had flow for four minutes? On a water heater at a house?
This ought to be good.
· Registered
He couldn't even bother to post an intro, what kind of guy do you think he is?
Reactions: jakewilcox
· Registered
I'm with you, I've never seen an isolation valve (is that code legal?) nor a low point drain. Hell, prep the new tank and swap it out while water is gushing out if we wanted to compare ideas.
· Registered
There’s no need for a bracket.
Our supply house delivers at no extra charge. Here’s the last one I did. Why make it easy for a handyman or homeowner to install the next one? No flex lines or Handy Andy fittings here View attachment 135832
I am curious about the foil tape on the single wall vent pipe. Is that a requirement in your jurisdiction? I have never seen that as a requirement. The vent for a Catagory 1 appliance is under negative pressure. The IFGC has very little information on installation requirements of single wall "vent" pipe. Very little on specifics as to how sections of single wall vent pipe are to be fastened together, sealed, supported. I am an oldtimer, and we always used at least 3 screws in each joint of single wall vent pipe. Never used tape. Anybody have jurisdiction requirements that go farther than screws in each joint? Such as how often the vent must be supported horizontally? For instance IFGC Chapter 5 vents says All portions of single wall metal pipe shall be supported for the design and weight of the material supported. That leaves a lot up to the discretion of the AHJ.
21 - 40 of 59 Posts
