Mark your territory
3535 Views 58 Replies 14 Participants Last post by  asapmarty
Computer Input device Netbook Computer keyboard Office equipment
Laptop Office equipment Material property Laptop accessory Gas
I have access to a fiber laser and am going to start etching copper pipes for water heaters, main valves, filters, softeners etc.
Permanent, cannot be removed.
See less See more
2
Reactions: 3
1 - 20 of 59 Posts
just do a bright and bold sticker that cannot be peeled off without a lot of energy
Fluid Gas Cylinder Machine Engineering
See less See more
Reactions: 2
You use pushfit fittings to connect water heaters ?
  • Haha
Reactions: 3
Its Never been an issue for me..
if you notice in the picture someone else installed a prv valve on the
water softener using them too.
Reactions: 1
I pull over to pee all the time.
  • Haha
Reactions: 2
Here in St. Louis the Expansion tank has to be 18" from the water heater connection. And those homeowner type connections do not shine brightly for a professional Install IMO.
Reactions: 5
Their is not a lot of difference between a pressed fitting on copper and a sharkbite
but both seem to work ok...
This is what I see all the time in many flipped houses ..
Wood Gas Watch Auto part Electric blue
See less See more
  • Wow
Reactions: 2
And a home depot water heater.................
Reactions: 1
I doubt that one came from Home Depot, it’s the professional series.
I buy most of my water heaters from Home Depot. They’re open 7 days a week and stay open until 10pm most nights.
I priced a 50 electric at supply house and came out cheaper going to Home Depot. I got the heater, expansion tank and drain pan at Home Depot cheaper than just the water heater at supply house.
  • Wow
Reactions: 1
that's usually the case but, to have it dropped off, sitting in the driveway of the home it's getting installed in is worth that extra premium from the supply houses to me.
Reactions: 2
Yeah it’s not worth the $60 extra difference for them to deliver a water heater. I’m not rich yet, I’m still installing water heaters for a living. Can’t forget that.
There’s usually a supply house on the way or a box store for me to stop off at.
PLUS: Rheem heaters from Home Depot come with a 1 yr in home repair warranty. So they’ll send someone out to repair it if I’m out of town or sick. That’s awesome for a one man shop.
Terry likes to see and be seen. 🫶🌈
Reactions: 2
Our supply house delivers at no extra charge. Here’s the last one I did. Why make it easy for a handyman or homeowner to install the next one? No flex lines or Handy Andy fittings here
Gas Composite material Machine Cylinder Wood
Fluid Electricity Cylinder Gas Machine
See less See more
2
Reactions: 4
My supply house also delivers at no charge but they’re just $60 more on a 50 gal electric Rheem if you pick it up or they deliver it.
Then it may come down to who’s open and who’s not open. Or can the supply house get it there when you need it there. Supply houses typically don’t do regular business on weekends.
Also The box store has more choices than supply houses here. Different heights and diameters.
I just found some leaking sharkbites leaking on a jack leg installed mess……
I literally just drove off from the repair.
Wood Pipeline transport Plumbing Gas Nozzle
Luggage and bags Gas Bag Cross Metal
See less See more
2
Reactions: 1
I don’t bother with stickers. To mark my territory I just pee on whatever I install. Best to do it when the HO isn’t looking. Don’t ask me how I know.
  • Haha
Reactions: 3
I can send you a mounting brack for that tank.
Also does no one install a boiler drain with there expansion tanks so you can easily isolate the tank and drain it with out killing the hot water.
Auto part Bicycle part Circle Metal Fashion accessory
See less See more
Reactions: 2
There’s no need for a bracket.
Reactions: 2
can they etch 3" copper? if so how much? i'd like to get the business name done and hang it on the wall in the office.
Reactions: 2
Can do up to 4”
Reactions: 1
Max size is approximately 7” wide though.
Reactions: 1
Why would you need to drain the tank? It has a bladder in it. It won’t get water logged.
  • Haha
Reactions: 2
1 - 20 of 59 Posts
