Have you noticed some faucet manufacturers have much longer plastic supplies on their faucets?
Delta told me 3 years ago that it was long as to allow a loop in the line to discourage cutting the lines to fit.
PEX C
It could just be the market/niche that I'm in, but I have absolutely no idea what you're talking about.Have you noticed some faucet manufacturers have much longer plastic supplies on their faucets?
There is a reason for it. I'll provide the answer if no one gets it.
Let me see if I understand PC... the long supply tubes increase the overall mass/volume of the faucet bringing the lead/volume ratio down... When the supplies are cut down, the ratio is no longer in compliance. Correct?PlumbCrazy said:Very good Plumb Nutz, if you cut them or modify them, the faucet would no longer comply with the Lead Free Law.
Consumer feels all warm and fuzzy, no lead in drinking water. Manufacturers support that with their marketing and advertising.
Plumber comes in and makes sensible modifications to fit his/her application and the faucet no longer meets standards. :furious: When I read about this, it just furthers in my mind why consumers don't trust plumbers. In the above scenario, the average plumber knows NOTHING about this and it would be an honest mistake.
Why can't manufacturers just comply with the law, instead of trying to find a loophole to exploit? (No pun intended).
It's a dirty little secret . . . just like greenwashing.
Absolutely correct. The law requires lead in products that supply drinking water will have to be less than .2% by 2014.Let me see if I understand PC... the long supply tubes increase the overall mass/volume of the faucet bringing the lead/volume ratio down... When the supplies are cut down, the ratio is no longer in compliance. Correct?
The fix?
Turn your angle stops downwards out of the wall so the loops can remain, or shorten the lines coming out of the floor of the sink base whether kitchen or lavatory, use angle stops once again, that way you can easily get those lines to install.
Out of all the Delta Faucets I have installed with this longer supply line, I'll never cut those lines because it's the probability issue that will throw a claim to its failure.
Seems like Delta, or my customers have started going back to the brass shank design because I haven't put those long supply type ones in for awhile.
Putting in more than just basic models, if that makes any difference.
Someone told me a while ago, that if Nathan catches someone trying to boost their post count illegitimately...KCplumber said:I asked a rep about the lenght of the supplys a while ago because a supply line from the valve can only be 24", he said it was part of the faucet so it could exceed the limits
