Started this shower and we went with a liquid membrane shower pan. When you do this method you have to make a "divot" in the mud bed to make a water proof connection to the shower drain. That is why you see a metal pan in one of the photos. We use stucco mesh to reinforce the membrane (even though with the membrane we use it's not necessary), and use fiberglass tape of the corners. Takes 3 coats on the pan. This is not the finished product, still will have to fill the divot with pea gravel and deck mud when we install the shower grate.
