What procedure can you use to energize a cable down waste line from inside a basement with a transmitter? Where should you put the ground clamp? This is for a 2" pvc line and I don't think my camera will fit. Thanks
This is exactly what I do. Get the extra long stainless tape. My boss gets annoyed every time the 100' one isn't enough because I argued with him that we should get the long one.Electrical fish tape. Energize that.
From what others have said you’d then need to unplug your machine from the electrical outlet.I can run a drain cable down the drain for that matter. I just didn’t know what to do with the ground lead on my transmitter.
Unplug the machine, then plug a banana clip into the nearest ground prong of an outlet for a true earth ground. Attach your transmitter to that. Easy peasy.I can run a drain cable down the drain for that matter. I just didn’t know what to do with the ground lead on my transmitter.
Put a ping pong ball or similar on the end and pray. The fish tapes come with a roll over end that does pretty well as is.What if you can’t get a fish tape to go down the drain, through fittings ?
My friend used a sonde on his spartan.
The fish tape advice was for pipes smaller than your snake can go or longer than your snake. I didn't think you had 100' of 1/4" snake.I can run a drain cable down the drain for that matter. I just didn’t know what to do with the ground lead on my transmitter.
Good luck with that. I’ve never had much luck using a fish tape in a 2” pipe with bends and drain goo. Like trying to shoot pool with a limp noodle. No fittings, better luck. Kinda like an old sewer tape but those are thicker and not as flexible.Put a ping pong ball or similar on the end and pray. The fish tapes come with a roll over end that does pretty well as is.
I use the fish tape in water lines. Polyethylene comes in 300' rolls so no joints.Good luck with that. I’ve never had much luck using a fish tape in a 2” pipe with bends and drain goo. Like trying to shoot pool with a limp noodle.
Went to the PHCC trade show a couple of times and a vendor was selling a battery operated vibrating fish tape to locate manifolds. you could hear it buzzing in the wall.When I have a leak under a slab sometimes I’ll put a fish tape down the line to find the next manifold hidden in the walls. Usually I have an idea of where the manifolds are but the tape confirms it without unnecessary cutting. Low tech hillBilly way.
