1 - 13 of 13 Posts
Lift Station Whisperer
Ah yes, the lowly shovel. Used by service and new con alike, and the bane of apprentices everywhere.
What kind are you carrying on your truck/van? Anyone have a favorite brand? Fiberglass, wood, or steel handle?
I have a standard spade, a sharpshooter, and a mini shovel for under houses. I'm considering a tile spade for narrow spots. I tend to prefer fiberglass handles or genuine hickory. All metal shovels are too heavy. Don't really care about the brand provided the blade is good and the handle is strong.
Ahhhh,the ole Mexican backhoe, nothing better
Certified DIY Advisor (Terms and conditions apply)
Let's get some pics
Nice Head, what’s in the bag?
This one, Altho it gets used more for cooking and camping vs work.
130116
I get the razorback brand shovels because they have the thickest blade and the collar is longer. These are important features for lifting manhole covers and septic lids. The rubber grip is nice too so the butt of the handle doesn't chafe your palm. I have tried fiberglass handled shovels but they're too flexible/weak.
I get about a year and a half out of a shovel before the tip gets broken too much or the handle makes a bad cracking noise. Then it goes into the tool crib for some helper to finish breaking ;)
130117
All I know is I've never found one that fit my hands.
Between going to school and helping out my father, I spend part of a year working for a concrete contractor. I was 24, 200lbs+ and fit. He was 50, 145lbs, maybe 150. But when it came down to it, that guy could work me right into the ground, day after day.
As a concrete guy, you spend more time grading with a shovel than digging. He preferred a square shovel with a particular tilt of the blade to the handle. It allowed him to work the shovel with the blade flat to the ground without having to bend over. One thing that amazed me about him is that he could look at a patch of dirt he was working and see even the slightest (1/16") irregularity even from a distance. RIP Pat!
I have Menards shovels, regular, short flat, short trencher an my crawl shovel.
This is my crawl/camping shovel. WWII Russian military shovel. Good quality, I’ve beaten the living snot out of it. I wish it had a slight angle to it, but it does the job.
I like the Razor Backs. I like the wood handle... Old school probably. I also like the big tabs to step on. I like them both for a flat shovel and a spade. They are also double riveted (most of the cheaper shovels are single rivet). I also carry what is called a drain spade, we call it a speeder, and I think you guys above me might call it a sharp shooter. I also carry a midget shovel for tight spaces; its not a military shovel, its kind of like a garden shovel or something, come to think of it, I don't even know where I got it.
Steel handled kobalt shovels from Lowes. When you break em you can walk into the store with the pieces and they'll replace em no questions asked no receipt required.
I wish our small hardware stores around here were like that. I had a shop vac motor fail after 4 months and the tool department guy wouldn't take it as a return. I had to pop rivet window latches to the sides because the handles wouldn't stay closed. As if they weren't going to throw it in a dumpster if they did accept the return.
1 - 13 of 13 Posts
