HO has slowly spinning water meter.
Checked the following first: Shut off the vacuum breaker feeding the irrigation system, shut off the main valve feeding the house. Meter is sill spinning very slowly. Installed a gauge on the sill cock above the main valve then charged the water service from the test ports on the vacuum breaker with nitrogen gas. The main kept eating gas but no pressure rise was observed at the sill cock so I know it's not leaking thru the cheap cpvc ball valve into the house and out a fixture.
Ok so we know that it's on the water service. Time to map the water service out. Can't use the navitrak because it's pvc. Opened up a solenoid valve on the irrigation system and opened the meter back up to leak some water fly threw and make lots of noise. Mapped out the path of the service via audio probe. Shut the meter and backflow back down; open the nitro bottle back up to 150psi so the leak makes some real noise. Passed down the path of the service with audio probe and found leak right in front of water meter.
Come to find out the service has been broken several times in front of the meter and repaired by the plumber that built the house (samco plumbing services, a competitor of mine). Nice repair samco. I like how they used a teloscopic and dresser even though there was a meter nipple right there and the meter it self is mobile because it's hooked onto polyethylene on the city side
. The sch40 female threaded on brass is good to......
