Seems they changed a boat load of codes in the IPC now.
I had to attend a continued education class for it yesterday for 3 hors and it took all 3 hours to go over them. It was mostly for designers and architecs, but all plumbers here in VA have to go.
Some of the things I remember were:
All shut off valves now MUST be stamped with NSF on them
There are certain primers that are not code approved
All PVC fittings above a ceiling must be a certain type (Did not catch what they were and it seems those from Ferguson are not approved for this)
There is changes to the DFI unit chart (Waterless urinals are a .5)
Waterless urinals while IPC approved can still be denied by VA code
NEVER use air on plastic water lines for pressure testing (Will post this one)
There was a change to stall partitions in relation to urinals
And a boat load more. I need to get an updated code book now. I told the teacher that when I do commercial work an architec has a pre approved set of plumbing plans and I cant change them, but like I said, VA says all plumbers have to go. Pisser aint it??
