Hi Everyone.
I'm looking for an inside cutter for 2" PVC sch. 40. Any experience, good or bad, brands, models, etc.
Thanks in advance, Mark.
I have a few different tools I use, I use a flush cutter from Grainger, hooks on a sawzall, another that works pretty good is something I found at fergusons, it attaches to the drill and has a blade in the front, the only thing is if your cutting verticle, put a rag int he pipe, the chuck loosens up and the bit falls out. Ridgid makes an inside cutter, pretty good from what I hear, but I don't think id does 2."
There are other things out there by Pasco that clean hubs on ABS/PVC, but I have found those to melt the pipe rather then cut out the pipe. Never really worked for me.
if your interested, I will try to find the item number from fergusons and get it over to you.
found a link to the fergusons one, works well, just stuff a rag int he drin if your doing verticle
http://www.faucetdirect.com/index.c...e=googlebase&cse=googlebase?CAWELAID=80929710
