1 - 20 of 23 Posts
Right now where the customer asked me if the high pressure I just diagnosed in his home would be related to the fill valves in his house.
The plumber before me?
Has replaced the fill valves in 3 toilets, 4 different times in 10 years.
Never once did they address/identify/resolve the high water pressure issue.
I'm going to make sure when I get this guys name today that I build collateral damage for him, for a good reason for screwing these customers over, not having the scruples to let the customer be aware of WHY these issues are presenting themselves.
I am going to have a field day with this guy's reputation and I'm not backin down. There's nothing worse than a deceptive tradesmen and I don't care if he "doesn't know" or not.
Good for you!
It used to make me mad because the employees at the shop where I used to work at could come and unstop a drain, but that was it. Never once tried to figure out what caused the problem.
I just did a prv last week and before that pressure was 165 psi.
Bet the T&P was blowing water out of the water heater at that pressure.
worst pressure I ever dealt with was... wait... I don't know what it was... because it blew up my pressure gauge. not as in "it exploded" but as in, "it pegged out and completley destroyed itself in an instant".
I estimated 550 psi.
they had ruined faucets, ruined WH, ruined everything.
the primary PRV had failed, and then the secondary one wasn't built to handle the high pressure.
I talked them into redundant primary PRV's and redundant relief valves plus a third relief valve piped up above ground level and shooting out over the road. that same road the water company guys traveled every single day. it was at a lower setting than the other two.
that whole thing cost them thousands.
Always Something
You can get higher (up to 125) at irrigation supply houses. So can we make fun of this guy untill he gets booted?
Always Something
oh he made an intro.....
with a q like that i doubt he a plumber...
1 - 20 of 23 Posts
