Lets say you have 2 options but you only have limited funds, and you are building a house or doing a significant reno.
1) Have a super high efficiency geothermal heating system installed your house with radiant floors and an air handler for cooling in the summer off of your geothermal heat pump, with say a boiler back up with indirect fired HWT, etc. With conventional 2 x4 or 2 x 6 outside walls with average batt insulation, poly vapour barrier, etc.
2) Insulate the living PISS out of your house. 2x8 or 2x10 outside walls, with the latest, high quality technology in insulation, say spray in foam with reflectix insulation as a vapour barrier if needed, etc. etc. With say just a condensing boiler with an indirect HWT and radiant floors and a radiant barrier in the attic with an attic fan for hot days, a high efficiency HRV for air exchange, etc.
Which is better? Efficiency, or conservation? Sure the premise behind them is similar but....
