1 - 20 of 45 Posts
You need Jesus, because clearly a logic based system of leading a proper life isn't your forte.
How do I make those characters with the dashes on top so I can type "forte" with the thing above the "e"?
Certified DIY Advisor (Terms and conditions apply)
Use a butane or oxy torch on the plastic, it'll come right off. No need to worry about the strength of the plastic. Albuterol Styrene has crosswoven plastic fibers. It'll expand with the heat and then shrink right back to how it was before.
Forté
hold down the E and they all come up on iPad
I don't have an ipad, or any other bloodletting device for that matter.
All hail Steve Jobs!!!!!! Make the sacrifice!!! Open your wallets!!!!
Acrylonitrile Butadiene Styrene
I see chemistry was not your Forté in school. Albuterol is an asthma medication.
If you were making a joke I salute you with my half mast.
129368
Being that the plastic and cast are just laying there not attached to anything,
why dont you just pick up the whole fitting and haul it out of that ditch
and just put in new stuff..... who in his right mind wants to re-use that old junk???
so are you like a retard or a plumbers apprentice ???
1 - 20 of 45 Posts
