I know a lot of guys will chime in with use a jetter, I have a 16 hp cart jetter which would probably work on 2" , 3" and 4" drain lines. I would like to know how you guys clean grease out of the lines from kitchen waste in the main lines and kitchen drains. How do you do it with a cable machine, or sectional cable or flex shaft what kind of ends do you use. I know there is hard grease and soft grease in the lines and the techniques would be different. I am interested in learning I just had a main line that was clogged with grease, I tried my 5/8" sectional cable with a carbide cutter it worked okay kind of hard to push past 20'. What about when you did not bring the jetter?
