Status
Not open for further replies.
1 - 5 of 5 Posts
A single handle shower faucet didn't want to turn off all the way, so I assume it's gunked up with hard water items within the valve.
My question is, how do I remove this valve, I've never seen this type before? There was a "U" clip at the top (which I removed), but I am afraid to go any further after removing it. The valve won't pull straight out... Does it need a pipe wrench and the whole thing unscrews from behind the fiberglass area?
For the valve replacement - do I need to rebuild it, or buy a new one?
Thanks for your help!
Nathan.
What ever you do, dont turn off the water with that pin out of palce. You need to put a pipe wrench on the brass part sticking out of the wall and turn clockwise. Reverse threads on that moen. Once you break loose the valve, you will see 4 set screws holding the cartridge in place. Take out the set screws and then you can remove cartridge.
We apologize for any inconvenience that this may have caused. This thread has been closed.
1 - 5 of 5 Posts
Status
