Just a quick swipe with an old putty knife. Time is money!
same here except the horn part, PVC flanges are sometimes cracked if ya look closelypull bolts out. clean off closet flange with putty knife. inspect toilet flange for damage......replace if needed. install new bolts & new wax ring w/horn.
I get it clean enough to eat off of. Then, I never use a wax with the horn, never.
Kinda an elitist attitude, don'tcha think?I eat off plates or well umm fastfood bags, but I don't ever use a wax with a horn.
Because they can shift when you send an auger down the toilet. That can cause a blockage or a leak. I put wax ring horns in the same category as mighty putty. If the flange is installed properly there is no need to put a "band-aid" in. Fix the flange.How come you never use one with a horn?
Elitist for not using horned gaskets?.... I would hate to see what you called him if he farted in public.Kinda an elitist attitude, don'tcha think?
They can get hung by an auger. I've seen them kinda crimped on the inner part of the horn. IF you set a toilet correctly, why do you need a wax with a horn...marketing gimmick.How come you never use one with a horn?
Same here, but almost every time i have to put new screws to hold the flange down because either the last hack didnt screw down or used drywall screws.I put on the latex gloves take putty knife scrape and then wipe it down real good so it is as clean as possible
