Hi all,
problem:
for the last 6 months or so I have started to notice an issue in my plumbing where I would get hot water in the cold pipes. Most severe at the sink right above the water heater and in the kitchen (likely the end of the line).
setup:
I have recirc pump hooked up to the water heater with a dedicated return line. Recirc pump is pumping return water into the drain outlet on the bottom of the tank.
diagnosis and things I have tried:
I have changed out all the mix cartridges at single handle showers and shut off washer machine pipes when testing. Did not help.
I have noticed that the cold inlet of the water heater is hot. When the cold pipes get cleared (running cold water or warm water), the inlet pipe feels cool, as soon as the faucets and showers get shut off, within seconds the cold inlet pipes will get hot again. There is no check valve or overflow tank. The dedic
also noticed that when I turn off the cold water inlet to the water heater the cold pipes do not get nearly as hot.
e sink above the water heater gets the hottest, and even when it eventually cools down, I can feel pulses of warm in the stream.
noticed if I turn off the Recirc pump the cold pipes are much cooler.
I’m thinking hot water is getting pushed up the cold inlet pipe and into the cold water lines. May be caused by the increased pressure from the Recirc pump pumping hot water back into the water heater.
am I missing something? Any help would be amazing!
problem:
setup:
