Had a call once for no water. I go out and find that the pump wire was broken. Told the HO and fixed it. Tested the pump while it was above ground and it did not run. Told the HO who said go ahead and replace it. Replaced it, then it would not run, so I checked the pressure switch, it was burned. Told the HO that it too needed to be replaced. He said replace it then, to which I did. Got the thing running and when I turned the faucet on the pump kicked right in, cut the tap off the pump stopped. Checked the air ballast tank, and sure enough it was full of water. Told the HO about the ruptured tank bladder to which he said "I bet you dont even know what you are doing! You are just replacing everything!" I tried to explain the order of events that led up to all this mess
First the bladder went bad, which causes the pump to cycle excessively, when it does this the points are constantly opening and closing which causes the electricity to jump the gap and burn out the points. The points stuck shut and the pump ran untill it burned out.
They did not want to hear it, I was just an idiot who knew nothing. Oh well, they paid me but I never got called back for anything
