Hello from Central Missouri
My name is William Cato, I have been plumbing since 1990. I live in a rural area 2 miles from Brumley. I just started my own plumbing service business BCH Plumbing. I also work for a contracting company from Denver North Carolina working on our local military base Fort Lenordwood, renovating homes.
The biggest pipe size I work with is 6" in drain and water mains. The largest copper fitting I ever solder was 4" using a candle torch. This is an eight torch tips that encircles the fitting hub and allow you to evenly heat the ipe and fitting for a good weld.
The worse plumbing nightmare was cleaning out drains at a turkey farm. I rooter several carcuses out of the drain. Nasty, smelly job. Took almost the whole day to clean out all twelve drians. I also smelled like blood and poop.
