[/QUOTE]
I like those wye and 1/8th bend combo fittings. They’re not too common in my area.
[/QUOTE]
He said wackerNo egging if the pipe is bedded correctly (foot tamp). I am a maniac about compaction. I carry a Wacker tamp as a key chain ornament..............
If it’s transite cement the ferncos always drip. Take the cement truck from putting in pond overflow pipes.Replacing some 4" concrete with the superior white pipe. @sparky , we even used hydraulic cement on the connection to the city's clay tile main! View attachment 132090
Not transite, at least not any that I've ever seen. This stuff had gravel in the mix. We had to leave a section under the flagstone patio; going back to reline it with some CIPP later.If it’s transite cement the ferncos always drip. Take the cement truck from putting in pond overflow pipes.
Well ya know, when doody calls!Loving this thread by the way. I enjoy seeing the way other plumbers around the country do it.
Yeah, I said do it.![]()
If by Asbestos you mean Transite, which is Asbestos reinforced concrete, then yes. We have a lot of that around here. I slowly cut it with a sawzall using a coarse wood blade and have someone wet the joint with a spray bottle or pouring from a bucket. It's the one time I am okay with leaving old pipe in the trench.23 years ago, ish, I had to tie into an asbestos main in SoCal. Anyone come across that?
Why would someone use a repair saddle as a coupling between two piping maters. Sad thing is I have seen municipalities do the same thing.More hole digging (sucking?). Unknown leak turned into a p1ss poor 8" connection. Out it came and in went a better connection. Night job so a lot of photos taken in the dark.
