here are some pics of a house I did for Habitat
Far as I know, you still have to run 3" out the roof here in IL. Transition made by a smooth increaser 12" or more below the roof.Illinois code doesn't make you increase anymore. It used to, and some inspectors still make you do it, even if it isn't needed. I used regular purple primer and cold weather glue. You are right, I used the 45's because of the footing.
In Chicago it still does.Minimum roof penetration is 3". A 3" stack doesn't need to be increased.
It's also a crown vent. Not allowed in IPC.If we installed a laundry trap that close to the floor we would fail an inspection. Looks good.
2 pipe diams. So 4"What makes it a crown? Does there have to be so many inches per pipe diameter between the tee and the trap?
Correct, JJ installed what is essentially an S-trap.2 pipe diams. So 4"
Good job Jeff!:laughing::jester:Correct, JJ installed what is essentially an S-trap.
Only thing wrong I see under UPC Code is trap from floor to low and stand pipe to long and no clean out, that's it, it is not a s-trap.It's also a crown vent. Not allowed in IPC.
