What makes you think I know everything?Aren’t you a plumber?
Depending on what's in there may be too hard for a little jetter to break up. If you had to drill into it too break it apart. That's some hard water!Last summer I spent an hour and a half cleaning out lime build up from a less than 2yr old heater!!! We installed it less then 2 years prior. The lower element burnt out from being submerged in Lime flakes. One of our HVAC techs changed the element but didn't clean any lime flakes out. 2 months later the new element burnt out. I got sent to replace it again.
I used a piece of 3/4" copper with my shop vac to suck up what I broke apart with a piece of rebar. I did all of this through the lower element bung and the drain bung. I also used my 18" long, 3/8" pilot bit to drill in and break it up. I filled a 5 gallon bucket. I had to leave a couple gallons in there to either side of the hole that I couldn't reach because of the angle.
Calcium buildup in the tankIts my house. It grumbles/rumbles for a half second to a few seconds. I also did install an expansion tank back in October.
It sounds like turbulent flow, like a vibration. Isnt water hammer when a fixture is turned off not on?
Haymaker is certainly more aggressive than vinegar. We have hard water and can descale a tankless in about 20 min with it.We pump vinegar to descale tankless up here. Would Haymaker or AO Smith Un-lime do something different?
No,1/2” flared copper for dip tube lololoCheck the little rubber flaps in the cold inlet/diptube.
@sparky Would recommend replacing the plastic diptube with some 3/4" OD copper, I'd have to agree.Just kidding on the diptube, but might as well check that too while you're in there.
I would just replace with a new heater if it’s that badI don't know if this would work, but it might be worth testing on a junk heater.
Drain it down halfway, cap the hot. Then dump some Haymaker in it and let set for awhile. Drain and rinse.
