1 - 17 of 17 Posts
· Registered
Road surface Asphalt Grass Water Wood
Went to repair a main service where the pool guy used a shark bite tee and it failed. I saw the main and proceeded to cut out the sb with my tubing cutters. I cut and cut and cut. Thought my cutters were stripped. Then cut it with a sawzall. Turns out that main is pex. Anybody ever seen it discolor like that? It straight up looked and felt like copper.
Another discussion would be how to tell if it’s PEXa or PEXb without seeing the lettering. I couldn’t tell so I had to crimp it all back. I also don’t like to use the crimp brass fittings underground. They corrode badly as well.
On another note, the brass they use in the shark bites is straight trash. They rot out quicker than the underside of a New York State pickup truck when buried.
· Registered
A few years ago I did a service call out to an old gas station in a podunk town and they had pex that was discolored so bad I swore it was pb. Turns out it was clear pex that had accumulated a film of nastiness along the inside of the pipe that made it look dark grey
· Registered
Yup, clear pex freaks people out.
· Registered
Underground gets a stainless sleeve and brass Corp fitting. I hate call backs.
Are you referring to Polyethylene lines? We've been doing that more lately. Been using a thicker PE that is fusion weld compatible too. Blue with red stripe I believe. This is for insurance paid for residential service line replacements.
When we do residential lines on the customer's dime we still use K copper for 3/4" to 1-1/4".
· Registered
Service lines where I live have to be K copper and nothing else.
· Super Moderator
It's called biofilm.
· Registered
1 - 17 of 17 Posts
