Good catch, posting that?
Are dry vents allowed in a DWV system or a Grease waste system
Whats the center line measurement of an ADA toilet off the side wall
whats the maximum height to the top rim of an ADA lavatory
What device do you use on a commercial lavatory to regulate hot water temp
T/F, A 3" DWV tee can be layed on its side for an underground branch.
What Device would you use to regulate pressure changes caused by heating water?
T/F Delta products are absolute garbage
Give yourself some credit. You're not such a bad writer after all.So here’s a little more info about me:
I’m almost 37 with 19 Years in the trades.
12 Years doing GC work (framing, roofing, siding, trim, flooring, drywall, paint, etc)
7 Years of doing plumbing, heating, AC and some electrical
MA Master Plumber
NH Master Plumber
MA Unrestricted Construction Supervisor
MA Oil Burner Technician
EPA 608 Universal
MA Sheet Metal Apprentice
OSHA 10
I have been told by apprentices that I’m a great teacher because I’m patient and most importantly I don’t talk to people like a POS. Your suggestion is something I’ve considered in the future after I blow my knees/back out 😂😂😂. As for now, those union paychecks are too good to give up.Give yourself some credit. You're not such a bad writer after all.
You've got lots of carpentry as well as MEP experience.
You should be teaching architectural or project management courses.
What you have, those people need.
ThanksGood answers. Welcome. Delta is garbage.
We’re not allowed dry vents here, and our toilets have to be 17-18 to center.
Welcome. Looking forward to some pics of work and horror stories from the noreast!
