1 - 20 of 26 Posts
I just got plans for a job that has geothermal heating and cooling, and it got me thinking how many of you guys work with geothermal or would consider it.
Your thoughts?
thanks.
i work with a heating guy who does it he runs all the pipes in the field and if there is a water heater tied to it i do all the piping for that its a nice system i know its expensive
I was thinking of doing my home with geo, I have 9 acres to burry pipe in. But never really got any further than thinking. I may do it this spring though.
I've done quite a bit of it. It's gets uber pricey. That unit better spit out quarters when it's running.
They make a great system though. I thought about it at my ponderosa but we went with scorched air .
You gotta be careful. There is a big up front cost to a geo. Alot of variables...field or well type. What spaces are you addressing. What are the deltas your trying to achieve. Location, location, location. Make sure you do your home work.
Homework
#1 - Homework. Like most of the new energy efficient systems, they will pay off only if you do the math.
Eqipment is probably the most expensive part. Plus you'll need a ton of PEX tubing (3/4" IMO).
Check with RadiantPanelAssociation.org - they may have some useful literature on the website.
Its not going to become popular thats for sure , its way to labor intensive as well as not cost effective with today's economy.
There is not enough training or Push from the industry either
Its a nice thought and will just be like the whole "solar thing"
But I do like it, but as I said, The system is flawed.
We piped 2 scools in 06 that used geothermal. There were 49 wells at each facility 200 feet deep piped in series used 1.5" fused poly looped down each well. $130,000 just to gets the holes poked with the loops grouted in.
I called a buddy of mine that does drilling and asked him for a bid. He was afraid his old rig didn't have 98 holes left in it. :laughing: He passed on it.
Lay it on me! I'm trying to get into it. It looks like you need a boring rig and fusion equipment to do it. Kinda pricey to get started.
I'll teach you everything you need to know:yes:
I've been told that non-cross linked polyethylene and poly propylene are usually the materials used in the ground loops. Pex would be fine, but I think it would add to much cost and for relatively tame pressures and temps that the loop is subjected to. The lower cost materials should work fine and I don't see the reason for going as heavy duty as pex for that application.
:rolleyes: :whistling2:
How is the drilling done? Do they sink a casing or just drop the loops in the hole and pour in bentonite(sp?) slurry?
I've plumbed a few houses that had geothermal heat and I'm about to start a couple more. The geo contractor I've worked with has a lot of experience. In fact, if he doesn't like what he sees in the mech drawings of a job as far as well location, piping and equipment go, he tries to convince them of the error of their ways. If that fails, he walks. BTW, his systems work. I have to agree with the points made about geo being a niche business. The need for deep pockets, ample land and the patience to wait for a far off return on investment definitely limit the marketplace.
Drilling was done with a regular water well rig. No casing.I believe the casing would inhibit heat trasfer. The grouting slurry is a special one that transfers heat very well. I would have to look up what it was. Don't forget to pressure test those loops before grouting:yes:
1 - 20 of 26 Posts
