1 - 7 of 7 Posts
I Figure 90 minutes for a basic gas pressure test, inspection, and permit. Am I out of line because everyone else around here charges 125.00 or less. I charge twice that. The permit is 15 dollars my cost and then I have to go back and get my gauge because I never know when the supply house will run out of them and not reorder for a week. 99% of all price checkers are checking gas test prices, I don't get it.
No Longer at This Address
If you are driving back to the site just to collect a $10 gauge you should not charge the client for it. It would be much cheaper just to include the cost of the gauge in your test price.
There are a lot of variables there to consider. How many openings? Does this include leak search? What about updating bonding? Changing out non-compliant gas stops?
Discussion Starter #4 (Edited)
As far as the guauge goes I don't want to buy a case of them and the supply house here is bad about not reordering. For what I charge I will do a minor leak search (exposed fittings) I will do some minor repairs, but replacing old stopps is extra. I usally remove old stopps and replace with a cap for the test. I have never heard of updating bonding.
sorry for my ignorance but what would be a situation that you would need to test a gas line? are you installing any gas lines or are you just verifying that the current ones don't leak or properly sized?
Discussion Starter #6
Around here people let their old gas systems go forever with out having them checked with the exception of commercial which are required to test once a year. Most people have leaks and don't know it until the gas company notices and pulls their meter then they are without gas until a plumber fixes and test the system and then the city comes and inspects.
Interesting. so to test, you would have to disconnect all appliances plus the meter then cap all lines. then you just put a 15lb air test for 15 min? thats our minimum test. find and fix leak and then you'd have to hook everything back up. I wouldn't do that for $125. I don't run into that at all, the average age of a house in my area is probably 20 years old. lots of new houses going up. I have done that in reno's I guess but thats after the contractor gutted everything out and we use the line for temp. heat. then run brand new and much smaller line later.
1 - 7 of 7 Posts
