1 - 20 of 30 Posts
· Banned
Hello guys I am redoing my bathroom and I hammered through the concrete and dug down to the 4” clay pipe cut it just behind the hub and I’ve used a 4” clay to 4” ABS Fernco fitting as seen in the pics I’ll post I can’t do a water hold test on these pipes so I filled a couple buckets with water and placed my garden hose in the shower drain and dumped the buckets down toilet drain , when I checked all the joints for leaks everything passed except at the side of the Fernco I joint that clamps on clay pipe , it’s very minimal leak but still leaks I left the water running down shower drain for 20 min and the leak dripped 2-3 times as seen in the one pic of the water that leaked out in 20 min , when I cut the clay I cut it as square as I could which turned out good , cleaned the pipe and pushed fitting on all the way and tightened clamp then I settled 4” abs and tightened clamp , I don’t have a inch pound torque wrench but I used 1/4” drive ratchet to tighten clamps and even after I found leak I tried to tighten more but am afraid to tighten it too much . Would this be a result of the clamp not tight enough ? Or is there a sealant I’m supposed to use on the clay pipe side ? The fitting is and will be burried under 2’ for gravel and 4” of concrete also will mention that the condition of the clay pipe is good , no cracks , gouges or pits in it so I’m not really sure if I did something wrong . From what I’ve read and been told , these are the connecting fittings for this type of connection and people swear they work and are good . Any insight , thoughts , fixes or solutions will be highly appreciated I have some knowledge of plumbing inside a house but this is my first time doing a burried connection and want it right , thank you and looking forward to speaking View attachment 135680
· Registered
Plumbing
The only thing I can think is check that the outside of the clay is close to perfectly smooth. Beyond that a sealant between the fernco and clay pipe would be my last resort. I personally wouldnt be worried about cracking the clay with just a nut driver.
· I Like Tater Tots
Like Terry suggested,get some dry hydraulic cement and flush a couple buckets down the toilet until the leak stops. It works similar to radiator stop leak but on bigger gaps.
· Plumbing since 1974
Plumbing and light HVAC
This wonderful website for professional plumbers letting someone (the o.p.) register and he doesn't own a T-torquer?
I suggest banning Jimmyjames.
· Reverend, R.S.E., Master Plumber
Nice Head, what’s in the bag?
Should I lose my vetting because I don’t own a “t-torquer”?
i mean I definitely would use it if somebody here bought me a seekonk 60in/lb 5/16” torque wrench, but I am not plagued by leaks on no-hubs bands or ferncos. Even to the dreaded clay pipe.
Same here, I’ve never had one and never needed one. They go from $70-$150 CDN, I wouldn’t be happy if I lost it.
1 - 20 of 30 Posts
