What's everyone's go to, to clear a main line blockage, not knowing the obstruction.
Customer does not want a camera...
Used to use K-1500 with spade head.
All of y'all who run Marcos, how do you get repair parts? Do you have them machines? Or is there a company who makes aftermarket parts for them?Marco with a 1/2 hp motor and 225’ of 3/4 innercore cable in 3-75’ open reels.
I make my own parts or have them made.All of y'all who run Marcos, how do you get repair parts? Do you have them machines? Or is there a company who makes aftermarket parts for them?
I need to get a 1/2hp motor for my LT90 MarcoI make my own parts or have them made.
I ordered top of the line bearings from McMaster Carr for the reel shaft and lubricated the interior with airplane landing gear grease.
I replaced the axle and added air up tires. I enlarged the loading wheel to 8”.
I milled the front torque tube bearing out of bronze and keep it greased with wheel bearing grease.
If you keep the bearings nice and tight nothing wears out.
It has an AO smith motor that I can get repaired or replaced at a local motor shop.
I think I’ve given you the number before of the motor and with the number a motor shop should be able to cross reference it to a new motor.I need to get a 1/2hp motor for my LT90 Marco
Yes please let me get those numbers again when u have the timeI think I’ve given you the number before of the motor and with the number a motor shop should be able to cross reference it to a new motor.
If you want it. It’s in my garage. Just let me know.
Rebuilding the old Marco was taken on as a joke but then I got into it and I love the machine. It’s stronger than me, bad boy will get away from ya if you ain’t careful.
Run the switch the wrong way and it’ll wrap you up like an anaconda
where did you get your marco?Marco with a 1/2 hp motor and 225’ of 3/4 innercore cable in 3-75’ open reels.
From a supply house years ago. It was ordered from Marco. Marco is out of business.where did you get your marco?
They are the only machine I know of that uses a right hand wound cablewhere did you get your marco?
What cable are you using?Dreel. Start with spade on 12" spring. I use a Bosch mud mixer to run it
