1 - 14 of 14 Posts
Ridgid tool user
So I finally got a duct rodder...Condux Cobra 5/16x500. The end has the adapter to screw attahments in it but it's about 3' long and I worry that it'll get jammed in a wye.
Do you keep the threaded attachment end on your rodder or do you just cut it off?
Watcha Got
I need mine. I think you will find it useful. From the looks of some of Ricks photos (pretty sure it was his pic), he sends it down a sewer, out into the street to a manhole so he can run a jetter upstream. They usually make several adapters for different scenarios.
Is that one a traceable rodder?
Ridgid tool user
Unfortunantley not traceable. I've been doing the same thing with tape and the tape seems to hold just fine. I was thinking of glueing a golf ball on the end to help with turns and offsets.
Ridgid tool user
Discussion Starter · #6 ·
My rodder came with an 18" flexible leader which snapped when going through a 4" san tee. The issue is when using the flexible leader, the end of the leader and rodder is about 7" and doesn't help at all making the turns.
Watcha Got
For turns like that a 3/16 may be better. 5/16 in 4" is great for the long straight pushes but I wouldn't attempt the 1/4 bends. 1/8 bends shouldn't be a problem though but you will need a roller or something because the blunt end will probably stick in a joint.
I Married Up
The end on the rod is 3' long? :eek:
The end on my Jameson is only an inch or two.
1 - 14 of 14 Posts
