Is it okay to hook up two water heaters of the same size and make in parallel if they are on opposite sides of the house?
Well first you can install an odd number of heaters easily. Plus it is easer to keep this type of manifold evenly sized on both sides. I see the first in last out install mostly in commercial installs and see all heaters working evenly. Where as the standard parallel install I see in residential homes, I have seen more failed water heaters due to, where one pipe leading into the tee is a hair longer than the pipe from the other heater, which causes the heater with the shorter piping to work harder.SewerRats
I don't particularily agree with BW's piping schematic. What is it about the design that you like? I have to wonder about the draw on a last out method.
tl
ao smith also has some excellent piping diagramsTanks in series, tankless in parallel.
