1 - 7 of 7 Posts
I went to a friends house today, he had just installed a kohler K-304 diverter with a K-405 transfer valve feeding shower head, hand held and tub spout. Shower holds tempature for 2-3 minutes and then runs cold. I would have probably fed the tub spout directly and sent water to the transfer valve by way of the diverter spout, but I really don't see how the way he piped it would effect tempature fluctuation. He has oil boiler with hot water coil and had no mixing valve I thought that maybe somehow pressure lost through coil might be affecting balancer, so I installed mixing valve on coil but it made no diffrence. Any thoughts out there
P.S. why do you always have problems helping friends and family?
Sounds like the tankless can't produce the GPM that you need. Assuming that only one showerhead operates at a time, you need approx 2.5 GPM. Problem is, that is at 50psig. If you are running a higher pressure, than you are pushing more water through the coil and proper heat transfer can't take place.
Try installing a flow regulator (I use Watts P-3) and a thermostatic mixing valve (Honeywell/Braukman AM100 series).
Hope this helps:)
1 - 7 of 7 Posts
