Tell me how a copper FIP to a dielectric nipple is a reliable connection in the plumbing industry when every single one I've removed always has buildup that is flow restricting and severe deterioration of the beginning threads of the dielectric nipple.
I've noticed they've changed the material choice that serves as the threaded connection to all thermal expansion tanks...what's the major malfunction of these dielectric nipples?
And don't think it's always homeowners and hacks that burn up/destroy dielectric nipples during installation; I've seen countless times in new construction where they didn't even jig the uprights, just threaded the FIP's and rolled with it.
Those dielectric nipples with the heat traps, small floating ball? DESTROYED when heat warps the function of that moving component.
I've been around long enough where tanks came without factory installed nipples, we just used MIP's and that was it. Always though, clogged right where the two connected to the steel tank.
I can honestly say I do not think every connection that has leaked, or is leaking at a copper to dielectric nipple is the result of installer error. I see this a lot, and installer error MOST of the time will reflect a leak right away on that application.
You can wrap teflon/dope it all you want; once you start threading those two pieces together you will lose any chance that you are covering the exposed top thread pattern to the nipple, and water becomes the #1 reason in conjunction with those 2 metals to start becoming defective.
I just reworked a water line last night, looked over at a 5 year water heater that's completely destroyed due to those connections. Never leaked for years...but apparently they did in the past 18 months which now the water heater is in need of replacement due to ongoing leaks that new connections to the tank will not resolve.
