1 - 9 of 9 Posts
every tool is a hammer
This was today's job. A clogged roof drain. It froze and clogged. It was letting rain water into the tripper room. It's a loooong room with coal conveyors running thru it. If the coal gets wet and sits, it starts heating up and can spontaneously combust. It was a 6" female hub, with a 6x5 soil X NPT bushing into a 5" galvanised line. I replaced it with a 4" no-hub drain. I had a short piece of no-hub from the drain into a 4" c.i. by clay tile fernco. The 4" clay tile o.d. is the same as 5" galvanised o.d.
Illinois Licensed Plumber
This roof was probably 150' off the ground. There is a waist high parapet all the way around. I am going back Tuesday to rod that same drain.
Does it have a clean out at the base? If so I can come and help. If you are rodding from the roof itself, good luck buddy.
Drain Cleaning Specialist
Ring Ring.
Me. Hello :)
Guy on phone. I have a clogged roof drain.
Me. Roof drain you say?
Me. Got an elevator to the roof?
Guy on phone. NO why?
Me. Sorry new. New Hampshire code does no allow fat Plumbers on roofs with out an elevator. :whistling2:
Guy on Phone. You don't say. I take it your fat?
Me. Yes sir.:thumbsup:
Guy on phone. I'll try someone else..:laughing:
Reactions: 422 plumber
1 - 9 of 9 Posts
