Yes I can see this being the case, dang I guess we really need to change the cutter wheels once every 4 years. :laughing:Sometimes when the cutter wheel gets dull it leaves and small raised edge on the end of the pipe. It is fairly easy to see after sanding the pipe (which is a must:laughing.
Umm, why sand??:whistling2:Sometimes when the cutter wheel gets dull it leaves and small raised edge on the end of the pipe. It is fairly easy to see after sanding the pipe (which is a must:laughing.
Another possible cause for the raised ridge is tightening the cutter too quickly. It kinda plowsi was thinking the same thing today (with a new wheel). very tight
British tube would be metric.We had some tubing come out to Great Britain that was out of tolerace and it gave us a fight at every fitting connection. The next order of tubing came from Cerro (I think) and it was perfect.
