Any specific trouble that you’re having with a tank type toilet ? I’d make sure it has a good handle and has a glazed trap way. Buy an aftermarket handle like the heavy ones wolverine sells, front mount.Hey guys,
What tank type water closet does well in an abusive restaurant environment?
I think a better test would be ground sausage stuffed into condoms. 😬🤣Champion is always impressive when the rep. flushes 13 golf balls
The Champion 4 is a good one. The only thing different from normal is the flapper, and I can find those almost anywhere in my neck of the woods.Champion is always impressive when the rep. flushes 13 golf balls at the trade shows and demo days, but non common insides is unappealing.
...... I want to avoid problems as I know how rough these Hoosiers can be even with Sloan flush valves
Put an expansion tank in the ceiling with a check on the incoming line.There’s only a 1/2” supply line
just try the TOTO....There’s only a 1/2” supply line
That’s all they require.There’s only a 1/2” supply line
This was in reply to the post before yours about putting in a Sloan valve. Thanks for everyone’s input.That’s all they require.
I’ve used 3-4 Gerber pressure assisted without trouble. If some some reason you can’t get the Krollers.Going with the Kohler pressure assist. Thanks Rock!
