Sizzle is good. I prefer Javelin though. Less odor.I bought a product at the supply house today called “Sizzle”. Going to give it a shot Monday.
Copper shouldn’t be used for urinal drains.Here's a recent thread with some thoughts
Urinal with internal trap
I'm curious what people use as well. I haven't done any chemical products on urinals/drains yet.
Any concerns with some of these products corroding copper or cast iron?
"Sizzle" is a 35% Solution of Hydrochloric Acid. Muriatic Acid is just another name for Hydrochloric Acid.I bought a product at the supply house today called “Sizzle”. Going to give it a shot Monday.
I run into a lot of copper urinal drains in the older buildings. They transition to cast iron at the floor.Copper shouldn’t be used for urinal drains.
Yeah, copper shouldn’t be used for urinal drains. Urine is acidic and typically destroys the copper in short order.I run into a lot of copper urinal drains in the older buildings. They transition to cast iron at the floor.
I usually pull the urinals off the wall so I can be sure both the trap and the drain are clear. 1.5 hours to pull urinal, snake w/ water running, reset urinal and rebuild the Sloan, if everything goes smoothly.
For the money the customer gets a pretty thorough cleaning and maintenance of their flushometer, urinal, and drain line.
I can almost always clear the drain with snake, k50, or mini jetter. With water running you're pulling out a mostly clean cable.
Maybe the acid isn't really necessary in the drain line itself when the snake/jetters usually get it.
I run into trouble when it comes to the urinal traps , my 1/4" cable doesn't usually go through. Then I'm using screwdrivers or coat hangers to pry away at the buildup. I usually set it over a drain or bucket with water running through the urinal trap.
A dose of HCL acid to loosen everything up might do the trick. With lots of water to rinse afterwards so I'm not spreading acid everywhere.
I hate those tiny urinal traps.
Agreed, copper shouldn't be used for urinals. Around here are lots of manufacturing plants and truck shops, old schools etc that are pre-PVC. Seems like I run into copper urinal lines on those buildings .Yeah, copper shouldn’t be used for urinal drains. Urine is acidic and typically destroys the copper in short order.
Over 65 yrs ago a local sports stadium was built and they used copper for the urinal drains. They had to to be replaced within 3 yrs. My grandfather replaced them.
This is not true. If you look up chemical compatibility charts, most metals are rated "severe degradation, not recommended for any use" with hydrochloric acid.Hydrochloric Acid does NOT attack metal(Except sometimes potmetal/diecast/zinc alloys), it only attacks metal oxides aka rust.
I completely agree, but I prefer to sell a new urinal.Sizzle is good. I prefer Javelin though. Less odor.
I'm just telling you what I have seen happen when I use it. I have been using it for years. I use it for work cleaning out minerals from urinals and toilets, unclogging drains, cleaning hot water coils, and removing severe lime build up from fixtures. I also use it at home to clean old faucets/valves/hose spigots/etc. that I am restoring/fixing.This is not true. If you look up chemical compatibility charts, most metals are rated "severe degradation, not recommended for any use" with hydrochloric acid.
They are completely different chemicals. "Javelin" is Sodium Hydroxide. I keep both the "Sizzle" and this powdered Sodium Hydrixide drain cleaner on my van. The powdered cleaner is no longer made/sold, it's very dangerous. It's powdered Sodium Hydroxide and a Carbonate. You start the water running down the drain and SLOWLY pour in a SMALL amount of it. As it goes down the pipe the Carbonate reacts with the water to give off Carbon Dioxide gas creating pressure.Sizzle is good. I prefer Javelin though. Less odor.
I'm not trying to bust your balls Skoro. Merely sharing some info that may not be commonly known, as I believe is one of the purposes of this forum.I'm just telling you what I have seen happen when I use it. I have been using it for years.
You are correct. Recall I was an engineer before I became a plumber. Lab tests for compatibility check for chemical reactions that may not be noticeable with the naked eye.What happens to a piece of pipe or a faucet for the 15mins that it's in contact with plumber's grade Hydrochloric acid is probably not the same as what happens in a laboratory.
Per SDS, both are an unspecified concentration of hydrochloric acid with a few other things added.They are completely different chemicals. "Javelin" is Sodium Hydroxide.
I tried Javelin it worked well.Sizzle is good. I prefer Javelin though. Less odor.
Did you use it on a plugged urinal? Did it smell any in the restroom and how long did you have to wait for it to open up.I tried Javelin it worked well.
