Anyone ever seen a chain knocker for Spartan cables? Either the .55 or the 13/32.
Or recommendations on a decent chain head in general.
Not really looking to descale. Heavily scaled CI is a replacement job in my book.I don't think a drum unit really spins fast enough to make chains viable for scale removal.
I did bolt some chains to my cable once because a line was so full of solids that I couldn't get it to mix with the water and flow.
Another time I bolted some chains to a length of 3/8" rod and ran it in my cordless drill. I had to descale this 5' length of 4" no-hub ci going through a foundation. They had put new plastic outside, and inside was all plastic. But the ci was so rough it was causing clogs. I hate no-hub crap.
Not sure what brand cable you run but if you have General get their 3" and 4" rotary saw blades. The trick is that the 4" set won't really fit in 4" so I will run one 3" blade with one 4" blade. I use this setup all the time and it will cut roots about as short as you can expect, leaving only about 1/4" to 3/8" sticking in the pipe.Not really looking to descale. Heavily scaled CI is a replacement job in my book.
Just looking for that extra kick for grease lines and roots. Roots should a full replacement too, but I'd like to be able to cut more out than I can with my C cutters and spiral saw. I know it's not ideal, but I'm not a fan of having to go back in a few days because the line is stopped up again and management is gonna fold because the customer is a Karen and complains loud enough. It would be helpful to open up the line more for the camera too.
I'm also aware that a jetter is the best option for both scenarios. My current employers have no desire to get a good enough jetter for those jobs. They're content with their modified pressure washer.
The C cutters General sells would crack if you tried that, they are hardened steel.Just flare your c cutter blades out so they scrape the full circumference of the pipe. That's the best way to use a drum cable. If you want to use a chain your best bet is a drill and sectional Ridgid cable. A drum spinning a cable at 230 rpms isn't gonna do much with chains.
I watched a guy break 2 Spartan cutters doing that.Just flare your c cutter blades out so they scrape the full circumference of the pipe. That's the best way to use a drum cable. If you want to use a chain your best bet is a drill and sectional Ridgid cable. A drum spinning a cable at 230 rpms isn't gonna do much with chains.
I have no experience with spartan brand blades, we used dcd blades at that company. Do y'all have the 3.5" round blades? Those flare out well. Tbh that's the only way to get roots completed cleared out of a sewer line with a drum though. If you're not scraping the tile you're not clearing it, doesn't matter how many times you hit that spot. You may look into getting a spartan to eel adapter and using expansion blades.I watched a guy break 2 Spartan cutters doing that.
My kid asked me some similar when our cutter came back all widened out. I’ve tried bringing them back into shape, even with heat and an oil quench. Snaps em.The C cutters General sells would crack if you tried that, they are hardened steel.
I like the pear shaped from DCD. But I’ve gotten use to the Spartan style. Have you looked into the three blade cutters? They can be a pain in the… with some fittings, but with enough time and patience they can descale cast and do a good job with roots.I have no experience with spartan brand blades, we used dcd blades at that company. Do y'all have the 3.5" round blades? Those flare out well. Tbh that's the only way to get roots completed cleared out of a sewer line with a drum though. If you're not scraping the tile you're not clearing it, doesn't matter how many times you hit that spot. You may look into getting a spartan to eel adapter and using expansion blades.
I'm all sectional right now between an r600 and the dreel. I do have the 4x6 expansion blades which is a 3 blade deal but I only stick that in the hole after a camera. For descaling I've been using the expansion cutter but I'm contemplating ordering a 3 and 4" chain knocker for Ridgid c10 cable and making a drill adapter for it.I like the pear shaped from DCD. But I’ve gotten use to the Spartan style. Have you looked into the three blade cutters? They can be a pain in the… with some fittings, but with enough time and patience they can descale cast and do a good job with roots.
It’s all part of his “unschooling” or life schooling, so he’s a student, not an employee. He’s fully covered medically through my wife’s work (or as best as we can in today’s current environmentI'm all sectional right now between an r600 and the dreel. I do have the 4x6 expansion blades which is a 3 blade deal but I only stick that in the hole after a camera. For descaling I've been using the expansion cutter but I'm contemplating ordering a 3 and 4" chain knocker for Ridgid c10 cable and making a drill adapter for it.
Hey on another note what do you do insurance wise for your son when you bring him with you? Do you consider him an employee and carry workman's comp on him? Or is it all under the table?
